Amp choice for small studio/listening system.
Posted by: BenW on 10 May 2018
I have a dilemma..
Putting together a small system to use for two purposes - a small studio for messing about with electronic music etc, and will also be used as a second system for general listening in that area. (I know, needs are fundamentally different for those applications, so this is a compromise all the way!) Main system is PMC/Naim in another location and won't be touched.
What I already have:
- A pair of PMC Db1i monitors.
- AudioLab M-Dac Plus
- Matched pair of HA-200 class A monoblock headphone amps
- Mac/Mic/Focusrite/Ableton Push 2 etc for messing about with.
The gap that needs filling is an amplifier, to slot between the audiolab Dac and the PMC DB1i monitors.
Funds are tight, so I've been looking s/h, and this is where it gets interesting. with a sub-£500 budget, there are a few options worth looking at -
- An original Nait 1 CB - tempting, usefully compact, had one before and loved it
- A newer Nait such as a 5i 2 - not heard, but seen good reviews - is it better than the original?
- A used NAP100 (again useful form factor)
- A older NAP 90 or similar
- (cough) an Audiolab M-PWR that matches the Dac. Would look neat, but I've not heard one either.
What would you do?
all other suggestions appreciated! I don't 'need' integrated though its undeniably useful for if needs change - so am I going to get a better amp for the ££ sticking to straight power amp?
