NAP 250DR causing power to trip at switch on
Posted by: pixies on 17 May 2018
I have a new 250DR (used with 272 and 555PSDR) and usually leave everything switched on. However I’m currently trying out a SL din/xlr interconnect resulting in having to power down several times. Every time I turn the 250 back on, it trips the safety switch on my dedicated spur.
I have found only one post back in 2016 referring to a similar issue, with the suggested problem being with the dedicated spurs circuit breaker. I assume if it was a problem with the 250, its internal fuse would blow (which isn’t happening). I also need to try plugging it directly into a normal wall socket to see if the problem is resolved (I’m just putting off turning it off and on again!). I will check this out with my electrician but just wanted to check with forum members of any similar experiences or anything else I should be aware of?
