Delays in finding newly added albums
Posted by: Campmusic on 20 May 2018
i use dbpoweramp to rip cds to a Qnap NAS. I find I can’t find the newly ripped album ... it takes 12-24 hrs before the tracks are listed on the Naim app.
I am wonder if this normal?
The Qnap is the TS 412 and is 75% full. but I have the same issue is with the backup Qnap TS 231, which is half full.
Posted on: 20 May 2018 by Bunny Colvin
This may depend on the server you are using. I have two UPNP servers running on my Synology NAS, the stock-standard Synology version and MiniMServer. When I add new music it will appear more or less immediately in the Naim app when browsing the Synology server but not so MiniM. I imagine the delay is due to the server re-indexing the media library... no idea why one server can do this in an instant and the other not!
Posted on: 20 May 2018 by hungryhalibut
If you load Asset onto the Qnap, albums will show up on the app in seconds, literally. Which upnp server are you using?
Posted on: 20 May 2018 by Peakman
Bunny Colvin posted:
Not sure about MinimServer on a Synology, but on my QNAP NAS, after adding newly ripped or downloaded tracks to the NAS, it is necessary to do a rescan.  I use MinimWatch to do this.  The process rarely takes more than a few seconds after which the new albums/tracks show up straight away in the Naim app.
Roger
Peakman posted:
Roger
Good to know! Thanks
Posted on: 20 May 2018 by Hmack
Same when using MinimServer on Synology.
I too use MinimWatch to trigger a rescan, and as you have indicated, it only takes a few seconds to complete after which all new albums show up in my Linn Kazoo, Lumin or Naim apps.
Posted on: 21 May 2018 by Campmusic
Thanks for all your comments and observations.
I have Asset, Minim and Twonky on my Qnaps, and I use whichever is suitable to my listening (although my folder setup works pretty well for my needs). I will check out minim-watch, which sounds useful.
I found the problem. When I ripped the album yeasterdy for some reason it did not add the wav suffix. I manually added it this morning and everything was fine. Thanks again for your comments - much appreciated.
