moving music from HDX
Posted by: m.paul taylor on 26 May 2018
I am part-x'ing my HDX and want to transfer the music to a NAS. I have been told I need to translate the files into FLACs before I do that but do not know how to do it. To make matters more complicated, In currently use a WD Cloud device but am about to change (thank you to the Forum members for your advice) to a QNAP 253. Will I easily be able to move the files from the WD to the QNAP?
Posted on: 26 May 2018 by David Hendon
The way to do this is to get the HDX to convert the files from WAV to FLAC first.  Assuming you are using a PC, you can load on the Windows Desk Top Client which you can download from Naim's website. The software isn't terribly intuitive and feels like something from a computer museum but you can probably work it out, or if you post back here, someone with more knowledge than me will tell you exactly what to do. But basically there is a convert option that you set and it will do it in the background, which may take a while if you have a lot of music.
Then having converted the files, you can save them to your NAS either by backing up from the HDX to the NAS or by copying and pasting directly from the HDX to the NAS.
The reason for doing the conversion in the HDX is that Naim uses a proprietary way of storing metadata in WAV and if you just transfer the WAV files, you will run into all manner of metadata issues which will potentially take a lot of work to sort out. This doesn't happen with FLAC.
When you change your NAS, you put them both on line on your home network and then you can copy the files over by copying and pasting or drag and drop or whatever. I would copy rather than move because if anything goes wrong you still have the original intact.
Then you set your upnp server on your NAS to convert from FLAC to WAV on the fly as it serves a file, if you are worried that you can hear the loss of sound quality caused by the Naim unit having to work harder to play a FLAC directly.
best
Posted on: 26 May 2018 by m.paul taylor
Thank David,
i am on the Naim website but cannot see how I download Windows Desktop Client. Can you help?
Paul
Go to Customer Support which is a link from top right of the screen on the Home Page, then go to Product Updates. Scroll all the way down and it's the bottom item in Control Apps.
best
Thank David,
Got there! They don’t make it easy!
paul
Double Thanks David,
HDX now happily converting to FLAC. I don’t know what I would do without the forum
Paul
Excellent! I'm glad I could help.
best
