Muso UPnP
Posted by: Simonb on 28 May 2018
confused, how can I dream music via my UPnP mode on my muso?
Posted on: 28 May 2018 by ChrisSU
Do you have music stored on a computer or NAS? You need UPnP server software running on that for the Muso UPnP input to find and play it.
Posted on: 28 May 2018 by Simonb
Hi
its the UPnP server I’m struggling with, how do you set it up?
Posted on: 28 May 2018 by Xenasys
As Chrissu says where is the is the Music stored then we can help with the UPnp
Hi
its stored on my iTunes
Posted on: 28 May 2018 by Richard Dane
You can stream music held in iTunes but you'll need to install a suitable uPnP server on your computer to do so.
Alternatively, if it's a Mac or iPad or iPhone, you can play directly from iTunes to the Mu-So through your wireless network via Airplay.
Posted on: 29 May 2018 by ChrisSU
Yes, you would need to instal a UPnP server such as Asset in your computer. Alternatively, iTunes might be simpler on a Mac. Use the Apple Remote app for control, and select the Muso as an Airplay client.
