Nac 282 connection questions
Posted by: maxmagri on 29 May 2018
nac 282: can I connect a non-Naim power amp through Link 2 socket? Or Standard socket? Please help me thanks.
Massimo
Posted on: 29 May 2018 by Richard Dane
What power supply do you have on the NAC282?
The pre-outs are on the power supply - usually three stereo pre-outs on DIN4s.  You can connect to a non-Naim power amp from one of these using a DIN4-RCA phono interconnect like the one shown in the FAQ.
Posted on: 29 May 2018 by maxmagri
Non-Naim PSUs. I can't afford another PSU.
OK, discussion of unauthorised modifications (which includes non-Naim PSUs on pre-amps etc.. ) falls outside of forum AUP. However, it should have a pre-out onboard, so you can use that. Otherwise, refer to the documentation that came with the PSU or contact the manufacturer.
thanks. now I understand.
