Superuniti BT - won’t play Apple lossless files
Posted by: Nigel Collins on 29 May 2018
I have just acquired a Superuniti.  My old streaming system was a logitech squeezebox touch through a Cambridge audio dac and a Linn Intek amp.  The server is a Logitech Media Server (which I like because it integrates well with iTunes although it’s a bit buggy).  Nearly all my music is ripped to Apple lossless (m4a).
The problem I have is that although the few mp3’s I have play well I can’t play any m4a files.  I get a message “can’t play unable to open stream”
can anyone help please?
Posted on: 29 May 2018 by Xenasys
Use a upnp server like asset and set to play as wav your Superuniti will thank you you may have to ditch LMS and use Naim App
Posted on: 29 May 2018 by CalumM
Can you confirm m4a files play OK if you try them on a memory stick on the front USB port?
Posted on: 29 May 2018 by Nigel Collins
Thanks both
xenasys - yep might have to do that but I want to keep a Logitech radio for kitchen so will end up running 2 servers
calumm - yes m4a files play perfectly through the USB port on front
Posted on: 30 May 2018 by El_Soldado
I’ve had no issues with SU playing ALAC.  I’m using MinimServer on an iTunes-maintained library on a synology nas if that’s any help.
Posted on: 30 May 2018 by NickSeattle
I never had issues playing ALAC on my NDX.  Logitech Music Server did not work for me at all, other than on my Squeezebox Touch.  MinimServer was the answer for me.
I did find AIFF seems to sound slightly better, to my ears, and solves all cross-platform file compatibility issues, at the cost only of extra storage space.
I have not found converting AIFF to WAV on the fly via MinimServer makes any difference I can hear.
Nick
Posted on: 31 May 2018 by SimonPeterArnold
The upnp server in LMS is not great. If your running it on windows there was a good upnp add on called White Bear I used to use that worked well.  Not sure there is an equivalent on Mac. You could run LMS and another upnp server in tandem though.
Posted on: 31 May 2018 by ChrisSU
I’ve tried using LMS on a Mac, and a Synology NAS. Once I’d finished endlessly faffing around making multiple attempts to instal third party plugins that are essential to make just about anything work, I still found it incredibly unreliable and temperamental.
Posted on: 31 May 2018 by Nigel Collins
Thanks all.  I tried using 'whitebear' but haven't got it to work yet but will spend a bit more time.  Think I'm coming to the conclusion to try either minim or asset and keep LMS for my Logitech radio used in kitchen.  A supplementary question - I use LMS to access radio 4 on catch-up - can i do this through the superuniti?
ChrisSU posted:
Quite the opposite for me.
Nigel Collins posted:
I find the iPlayer radio app the best way to access BBC catchup. I would just use that with Airplay and an Airport Express.
