Help please! Introducing a NAP 90 alongside NAC32.5/SNAPS.
Posted by: iray on 03 June 2018
Hi,
I'm new to the forum and have been trying to educate myself with posts about psu, pre and power amp connections, but would much appreciate some help with my particular configuration. The manuals I've found online are helpful but I'm still pretty confused.
I have a NAC 32.5 running single rail from a SNAPS. The 32.5 has been modified by the previous owner to give it RCA inputs. I have, up to now, had the 32.5 connected directly to an Arcam Power Amp with good sound so far.
I'm hoping I can leave as-is this direct connection from the 32.5 to my Arcam Power Amp and use this to supply the High Frequency to my speakers (Jamo Concert 8's). I'd then like to add a recently purchased NAP 90 to supply the Low Frequency to my speakers.
I believe I should connect the NAP 90 to the SNAPS for both 24v power input and the 2 channel signal.
The SNAPS has 4 sockets of the 'larger diameter' (older?) kind. Sockets numbered 1 and 4 are 3 pin and sockets 2 and 3 are 4 pin. Socket 2 (4 pin) is currently connected to the NAC 32.5. All good so far.
The description on the rear of the SNAPS is confusing to me. It reads as follows:
ONE AMP: Socket 1 to Amp, Socket 2 to Pre-Amp
BI-AMP: Sockets 1 & 4 to Power Amps, Sockets 2 & 3 to Pre-Amp/Crossover
TRI-AMP: Socket 2 to Crossover, Socket 3 to Pre-Amp. Link sockets 1 & 4 (or link internally)
So, finally to my questions:
Can I connect the NAP90 directly to the SNAPS for BOTH power supply and signal? I think so.
If so, do I use Socket 3 (the other 4 pin socket) ? On the above SNAPS description there is no mention of using Socket 3 to feed a Power Amp. I suspect Sockets 1 and 4 are supposed to feed 2 x Power amps (one each Channel) but I want to feed a single NAP 90 so how do I connect please?
If the SNAPS is providing 24v power to the NAP 90 do I still need to connect the NAP 90 to the mains (there is a 'kettle style' mains socket on the NAP 90)? Perhaps the mains lead to the NAP 90 only serves as an EARTH when there is a SNAPS 24v power feed?
If it IS possible to connect the NAP 90 to the SNAPS and to use this to feed the Low Frequency to my speakers, is it really OK to take the High Frequency feed from my other (Arcam) power amp, or will there be a volume imbalance? Perhaps both amps must match precisely in a 2 Power Amp setup so I would need a second NAP 90?
THANKS for bearing with me and reading my long, drawn-out query. Please excuse my lack of understanding. Your responses will be greatly appreciated.
Ray
