Uniti Core backup issue
Posted by: Laxton on 08 June 2018
Hi All,
I’ve just purchased a Uniti Core and I’m having some problems with backing up the Core to my Synology Nas.
The Nas is accessible from the Core and the Core managed to write some files such as a backup folder in the share. However, the backup fails less than a second after starting and the status shows error with no other details.
Backing up to a local hard drive works fine.
Does anyone know I should go about troubleshooting this?
Thanks!
Posted on: 09 June 2018 by Rich 1
Does the Core have the latest firmware. There was an issue with Nas backup with the old. I have a Qnap Nas and had issues backing up. Created folder in Nas called Naim backup. I then had to remove all hidden folders such as recycle bin that was created automatically within the new folder or the backup would fail, another words the backup folder had to be completely empty. Using the Naim app, select new backup and navigate to the Nas backup folder that you have already created. Fingers crossed! Rich
Also take a look here ;   https://www.naimaudio.com/product/uniti-core/support
Ask question   Create a backup
Rich
Posted on: 09 June 2018 by Laxton
Thanks Rich.
My Core is on firmware v2.5.
The target network mount folder is totally empty with no Recyclr bin.
I’ve tried to trawl through Naim’s support on the Core and the information on network sharing is quite lacking.
Posted on: 09 June 2018 by David Hendon
Naim are working on the Core seeing network shares more reliably so I suggest you wait and see whether it gets fixed in the next Core firmware update, which hopefully shouldn't be too long now....
best
Hi David, hopefully Naim will get this sorted out soon.
Hi again Laxton, are you using android or iPad, I seem to remember I had better success with iPad (I think} it's a while ago now and memories not what it was! So if you have both Android and apple try again with the the other OS. Rich
Hi Rich, I’m using an iPad to acces the Core.
Posted on: 10 June 2018 by Rich 1
Does anyone in the family have an android phone that you could download the app onto? It might be worth a try. Also would be worth phoning Naim support rather than just waiting for the next update, I found them very helpful in walking me through problems. Use the feedback tab on the app to document your problems, Naim read that but don't usually read the forums. Sorry I can't be of more help  Rich
Posted on: 17 June 2018 by David252
I have a core and a synology and all backs up fine.
Make sure in the network settings on the core that you put the riht user name and password in for the share on the nas.
The network settings on in the section to setup local shares.
I use the admin user name and password as it gives the core full rights to the synology.
Posted on: 18 June 2018 by Laxton
David252 posted:
Thanks for the tip. I'll give it a go.
I’ve tried setting the username and password in the network settings and the Core can see the network shares. However I’m still faced with the same issue where the backup process throws an error immediately after the backup begins.
Posted on: 18 June 2018 by Phil Harris
Hi,
Can you contact me directly so that we can take a look at the issue that you are having and see if we can recreate it here...?
You can get me on either phil.harris@naimaudio.com or support@naimaudio.com...
Phil
Phil Harris posted:
Hi,
Phil
Thanks Phil. I’ll drop you an email.
Posted on: 28 July 2018 by Mike Sullivan
I've just run a backup to a USB drive, all went okay. Now trying to update the backup and it's wanting to reformat the disk to back up. I had it unplugged between time. Does the back up drive need to stay connected, or am I doing something wrong?
Posted on: 28 July 2018 by David Hendon
Mike Sullivan posted:
No you don't need to keep it connected between backups. If you restart your Core (not just wake it up) it will probably sort itself out. I have reported this issue in the beta group as I have met it too.
best
David Hendon posted:
best
Thank you David, that’s very helpful. By a restart, is that the long press “deep sleep’ mode followed by a wake up?
Best take the power off completely, wait a few seconds and then start it as per normal. This is a restart I am suggesting not a reset!
best
best
It worked! Thank you so much.
