How to get Synology playlist to be seen by Naim App on IOS
Posted by: MikeOR on 09 June 2018
I have a Synology NAS, using Audio Station.  Naim App on my IOS phone.  Works fine.  In that past I created playlist in Audio Station and I could play them from the Naim App.  However, now from the Naim App, it says "no results" when I navigate into any of these playlists.  They all still exist in Synology.  If I create a new playlist in Synology, it does not show up in Naim App.  Same if I edit a playlist.  Seems like I need a way to tell the Naim App to reconnect to these playlists.  Is there a way to do that (e.g. kick off a synch)?  I am using 5.9.1 of the Naim App
Posted on: 10 June 2018 by Nogbad The Bad
Go into the Media Server application, use a Custom DMA menu style, I use Custom 3 then select Customize.
Hit create name = Playlist & type = Playlist, then back to the main menue and hit apply.
Make sure your playlists are group playlists, they should then appear in the IOS app under playlists.
The above seems to work for me.
