Used NAP250.2 or used NAP250DR?
Posted by: brahms86 on 10 June 2018
Hi all,
after some consideration I determined I would like to upgrade my Supernait 1 at first by getting a separate power amplifier. This is mainly because I am more sure about the "final configuration" than with the pre (282 or 252).
Since I buy only used: Should I a get a used 250.2 or directly a 250DR? Price difference at eBay is around 1.500 EUR.
So my reasoning is as follows: Getting the NAP250.2 will quite certainly make a nice positive impact on the performance of my setup and this what I enjoy most (like I did when I recently replaced the Supernait's internal DAC with a used NDX), but after some months you get used to the new SQ level and you are looking for more ;-)
Having the 250.2 then upgraded to a DR version would be the next natural "upgrade event" and would also give access quite new hardware (provided service is included). I am just not so sure, that eventually this two-step approach will be eventually more expensive ... any thoughts about it?
Kind regards,
Steffen
