NDS dropped a channel. What have I done?
Posted by: Bruce Woodhouse on 11 June 2018
Been swapping around a 52 and 252 in my system which has involved a few power off/on cycles for everything and also moving the NDS (carefully) from the top of the stack a couple of times.
So now... no LH channel with either pre-amp in place from the NDS. Other inputs are fine.
I've checked the interconnect by swapping in an old one-same result. I have racked my brain for something simple or stupid I may have done but the only conclusion I can come to is that I have somehow annoyed or damaged the NDS. I do have a second system that I could in theory stick the player in to test it but it means a lot of dismantling to do this as I'll have to pull out a power supply etc etc, and I'm struggling to see how it may be any different.
Any suggestions before I start weeping and ringing to send it for repair? Logic tells me it must be the player but I'd hate to send it back and then discover I had missed something obvious.
Thanks in advance
Bruce
PS Never did get to do the comparison!
