So my existing setup was 2 x TP Links MC powered by 5V IFI Power supplies, which i have added and removed in the past, for me it is a MAJOR improvement.
I have waited for a few months before considering LPS, after help and guidance from the guys here, i opted for a MCRU 2x 5A Output LPS.
I also added a new Ethernet cable, so also wanted to wait for that to settle, minimize variables to assess any gain/loss.
SUMMARY = WOW – I wish I spent more on the LPS, you know it is good when your controlled 6 tracks A-B-A goes out the window and your onto numerous other tracks to re hear : )
EASE – This is THE main gain, music just flows, hard to describe but you close your eyes and sing.
UNRAVEL – I used an old trance tune, which keeps building with so many layers and a deep baseline, I know and have used this as a test/demo tune, the LPS addition makes the SMPS seems muddled and wrong, now control of multiple layers with ease
TIMING – Linked to EASE, but I expect this to improve as the LPS is stone cold.
ORGANIC – It just sounds so fluid, natural, vocals where good before, but now so, so sweet
BLACKNESS – Very eerie
BASS – Bloom from 2.6 nearly gone, the stop, start, decay of notes feels effortless and very natural now.
DETAIL – Another onion layer peeled away, lots of micro detail now clear, prior was muffled but now prominent and detail behind it apparent.
SOUNDSTAGE – Further out towards listener and better separation of vocals/instruments
DYNAMICS – Seems less, bit rolled off at the top end but only on some instruments, need more run in time maybe, but not negative
This is from cold, I expect a further gain, as even with the IFI a week or so in they settled and improved.
Posted on: 21 June 2018 by Obsydian
I replied earlier must have been moderated...
Thanks to your advice I choose the dual MCRU, but after hearing the upgrade I think the Uptone LPS at twice the price may have been better, but it was to many boxes and more power units.
I spend more time on CA listening and learning, for sure their network thread has brought FAR GREATER improvements than box upgrades at many £1000s more.
I think now the Cisco 2960 momentum builds, maybe others may try other network tweaks.
French Rooster posted:
Obsydian posted:
Hi FRENCH ROOSTER, yes i went with your MCRU suggestion, the Teddy seemed hassle with import duties and warranty.
I kinda think maybe 1x Uptone LPS 1.1 or even two would have been better, but at £450 each, seemed a gamble for a "pointless" power supply change
i think you made the good choice. 2X 450 is a bit expensive to power fmc, and i am not sure you would have heard a difference. Let me and us know when you receive the second genth lan cable. Enjoy
The Ghent (Router to switch) is on hold, although I do like what it does, but MIKEB got me interested in the Miechord, ideally I'd like to demo that, then decide at least keep the Router to Switch to Media Converter 1, the same cable (i.e. Ghent or Miecord)?
The last leg, Media Converter 2 to Streamer I will keep the Chord Indigo Aray, at to me that still beats them all.
With the MCRU LPS I managed about 5hrs listening today, was advised 30-50hrs to settle in.
Posted on: 21 June 2018 by French Rooster
Obsydian posted:
Obsydian posted:
i had the meicord before and found it well balanced, neutral, and musical. A good lan for the money. But the vodka, after run in, is a bit more dynamic and the sound has more body.
The audioquest diamond is well above the too and the vodka is globally better i feel. I don’t think the meicord can compete with your indigo. But who knows, it is just my feeling.
You can buy the meicord on amazon, so easily return it.
Posted on: 22 June 2018 by Obsydian
The AQ was not to my liking, it was warmer and rounded, i felt less dynamic.
The Meicord interested me as it it unshielded.
I think i will let the MCRU LPS settle, my only slight hesitation is a slight loss of dynamics (for some instruments), but to be honest i thought that was more down to the blacker soundstage (lower noise floor).
This morning i was thinking yesterday was the first time in a while i have hit a playlist and just let it play to the end.
For ease as i do like the Ghent, i will order another (Router to Switch), then possibly a better mains cable for the MCRU LPS, then just level it alone and focus on enjoying the music and at a later day deciding whether to stay with Naim streamers or move on elsewhere.
I am still bitter about 2.3.1 and plan one last downgrade, as that just had something special, coupled with the latest improvement, i could be VERY happy, but it is a dead end as in no support from Naim.
