NDX - Radio 3
Posted by: Graham Hull on 03 September 2011
Just bought an NDX. Does anyone else have problems with the two Radio 3 feeds on iRadio? The Hidef test link on Naim's choice doesn't connect at all and the standard HD feed has distortions - popping sounds every few seconds.
Posted on: 03 September 2011 by CSAS bite
I've had no problems until I read your post!  Hi-def is OK, I had no problems connecting via Naim Choice, but the standard Radio 3 feed is clicking for me too.
Al.
Posted on: 03 September 2011 by Graham Hull
Just tried the hidef test link again in Naim's choices and it worked Ok. I had stored a link to this and this doesn't work. The URL must have changed.
Posted on: 08 September 2011 by kassos
I have had no problems via Uniti - until about a week ago and am now getting popping sounds on Radio 3Live. Any suggestions?
Posted on: 08 September 2011 by Focalist
No problems here using a Squeezebox and IPeng, and never had any. Love the HD feed. Sorry you are having issues, not sure what it can be?
Posted on: 08 September 2011 by Graham Hull
How do we make Naim aware of the issue? Maybe their employees only listen to Floyd.
Posted on: 11 September 2011 by kassos
I don't think the "popping" noise is a naim issue - I suspect BBC as all other stations work fine. But Naim choice Hidef feeds do not work at all for either bbc R4 or R3 so that might be a NAIM choice issue. Recently upgraded to Version 3 Software.
