Paulie posted:
I have a UnitiCore (running firmware 2.5 (9144) which had, until very recently, been discoverable by three televisions (Bang & Olufsen) and were able to play (via their own built in media players) music off of the Uniti. All of the devices are on the same wifi network in my home and the playback off the Core was via that wifi network. Nothing hardwired. Suddenly, the player is no longer visible to the televisions. I've tried numerous restarts, reboots, unplugs..... the whole kit..... and still, no love. The one thing I haven't been able to try is to disconnect (sign out) the Core from the wifi network and then have it rejoin (sign in again). I've unplugged the LAN cable from the unit and waited and plugged it back in, but that's not the same thing.....
Any help, as always, most appreciated.
If you have powered off and repowered everything ... then there are some things to try...
if you know how to use ping... try typing ‘ping 239.255.255.250’ from a console on a mac or pc connected to your home lan... what do you see? Do you see the IP address of your Core returned along with TV IP addresses?
if you see the Core address returned, the chances are your home network is fine.
If not, or this means nothing to you... the next thing to check is to see if your WLAN access point (perhaps on your home router) has a setting called ‘IGMP snooping’. If it does try disabling it... repeat the ping check above or simply try to discover your Core again.
Sometimes this IGMP snooping capability can trip up on consumer equipment and your TVs might have caused this to happen. Ideally you want this enabled for optimum Wifi performance, but if not working properly then switch it off.
Failing that you should try an alternate WLAN access point, like a Ubiquiti AP or an Apple Airport Express and connect to a switchport on your home router.
