Naim app bug
Posted by: JamieWednesday on 22 June 2018
Anyone else suddenly getting a problem with overlapping text from different sources in the now playing section at bottom of screen?
For example if I’m playing from usb and then switch to Tidal, the usb icon and last song title remain displayed and are overlapped by tidal icon and new song text, rather than replaced. So you just get a jumble of the two.
Cured only by turning iPad off then on again.
Posted on: 22 June 2018 by Trevor Wilson
Hi
thanks for reporting I’ve Passed to r&d to replicate
trevor
Posted on: 22 June 2018 by JamieWednesday
Posted on: 22 June 2018 by ChrisSU
Do you mean this:
I noticed it a few weeks ago and reported it, so hopefully it is on the radar for a fix.
Posted on: 23 June 2018 by JamieWednesday
Yep, same as.
