Nait XS 1 weak and distorted on one channel
Posted by: sjw on 23 June 2018
weak and distorted on one channel... it 'follows' from side to side if I swap speaker cables over
Any bright ideas please?
thanks!
What year was the XS made in please?
I am guessing 8/9 year s old
I can't get to the serial number
Is it like that on all sources? If so, it may indicate that it needs some attention.
sjw posted:I can't get to the serial number
It's what the camera is for on your smartphone ![]()
If so on all sources: check the connectors...
If you're using an external power supply check got dry joints in the SNAICs, if not remove and replug the 'link plug'.
If still not good, may need attention as Richard says.
thanks
will try flatcap leads connections etc
So, does your Nait XS work properly without the FC then?
A good call from Huge; yes, check the connections, particularly if you have a flatcap in the loop. Just make sure you power down first - disconnecting or re-connecting a SNAIC while powered up can send a shrill squeak through the system that can easily take out a driver if you aren't careful.
Thanks I'll have to try and find the link plug which I haven't seen for 8-9 years or order another etc not going to be a quick resolution
Cheers Stephen
sjw posted:I'll have to try and find the link plug which I haven't seen for 8-9 years....
Your dealer might be able to lend you one from an XS2 or SN2 if finding yours proves impossible.
Found it... and same thing only trace of sound on one channel
I guess its a dead channel on the amp which is a surprise and a shame at the same time!
