NNP01 as amp via AV2
Posted by: angelodipa on 26 June 2018
Hello to all
I would like to understand if I can use an NNP01 (or NNP02) simply as an amp to connect to the AV2 to drive the "rear surroud" speakers and then move from the current 5.1 to 7.1 configuration.
thanks in advance for your always valuable suggestions!
Posted on: 27 June 2018 by Richard Dane
Unfortunately I don't think an NNP amp can be used in this way.  You're best off looking for a proper Naim amp.  Cheapest option would probably be a s/h NAP90/3, which should be perfect for rear effects.
