Core does Not see my Synology 916+ NAS
Posted by: tmtsui on 02 July 2018
Hi,
I am a new user of Core.  It is wire-connected to my home network.   And within the network, I have two more NAS on it — Synology 916+ and IO-data Soundgenic.
The Naim app sees the Soundgenic without issue but not the Synology that I am planning to put the backup onto it.
Searched the forum and found no solution.   I’d appreciate if any one could give me a helping hand.
Thanks a lot.
Posted on: 02 July 2018 by ChrisSU
Have you followed the steps for 'Creating a backup' on the Core support web page?
Posted on: 02 July 2018 by tmtsui
Hi Chrissu,
Do you mean this article: Synology : https://www.naimaudio.com/site...ogy_DS212j_Setup.pdf
I read that and tried to follow the step.   But the content are not up to date for the current DSM 6.2.   For example, there is no Win/Mac/NFS anymore, and I couldn't locate a similar replacement item.
Best
Dear Chrissu,
Thanks a lot.  Have figured it out how to do it based on the instructions in the article.
Thanks very much.
Glad you've got it sorted!
Yes, I did.   Thanks a lot.
