Newbie question
Posted by: ECM on 09 July 2018
Folks,
Just getting my chrome bumper stuff running again. Started with the Nait 1 which was perfect until I tried some Linn cable to compare with my old NAC 5 cable. Something went wrong and I lost one channel due to a loose banana plug. Put the Naim cable back in and channels came back but suddenly there is low volume on the phono section, which is what I was using. No problem with other line ins.
The phono sound is sweet on both speakers but volume has dropped 80%. I'm sure that I switched the amp off during change over but I've obviously done something to an amp that has served me well for 20 years.
Any ideas on what has happened?
E.
Posted on: 09 July 2018 by The Strat (Fender)
E,
Ph wish I could help with that one.  I’m sure someone will be all along soon to cast some light.
Lindsay
Posted on: 09 July 2018 by cdboy
Are all the front buttons where they should be? Does the tape button effect the volume etc?
Posted on: 09 July 2018 by ECM
Folks,
Good point about the buttons. I'll do a recheck to see if I forgot something.
E.
