nait xs drive dynaudio excite 34
Posted by: pamzz on 10 July 2018
Hi guys , i am real nubie in audio , i am planning to buy nait xs2 to drive excite 34 , does nait xs2 strong enough to drive dynaudio excite 34 ?? or underpower ??
Hi Pamzz. I've got the Nait XS (first generation with a bit less power than XS 2) driving the Excite X36 (bigger than X34) without any issues. So I think your pairing should be safe and very enjoyable!
Agree with the above. I have a friend that is driving x38 with an XS 2. He says it has plenty of power for them.
Yep it’ll be totally fine! I used to drive Focus 260s with the 60 watt version and now I drive the same 260s with a Uniti Star.
Great speakers by the way I had the X32's for a year or so and of course they do love a bit of power but the XS will do a great job.
sihctr posted:Hi Pamzz. I've got the Nait XS (first generation with a bit less power than XS 2) driving the Excite X36 (bigger than X34) without any issues. So I think your pairing should be safe and very enjoyable!
so i upgrade to x38 still will be okay , without undepowered ..
pamzz posted:sihctr posted:Hi Pamzz. I've got the Nait XS (first generation with a bit less power than XS 2) driving the Excite X36 (bigger than X34) without any issues. So I think your pairing should be safe and very enjoyable!
Yes it will be fine! My friend uses an XS2 with the X38s and I use Focus 260s with a Uniti Star
Although Dynaudio has a reputation of presenting difficult loads for amplifiers, the Excite range is actually pretty straightforward and should not be a problem. The Focus was starting to become more demanding but it was the Contour and Confidence that needed a careful choice of amplifier. You should be fine, and, Dynaudio make superb speakers so you will not be disappointed.
