Problems with NDAC connection
Posted by: sjostrom on 17 July 2018
Hello friends!
I just bought a second hand Naim NDAC witch currently is connected to my Mac Mini via Toslink and to the Supernait 2 with rca-wires. As a first improvement I bought a second hand 180 5-pin to 5-pin naim interconnect. However, when installing it I only get sound from the left speaker. Unfortunately I don't have an additional din-cable to try it with and no Naim friends to borrow from. I have tried using the CD, Tuner and HDD inputs on the Supernait, but the problem persist.
Have I bought the correct spec cable and is there any way to test if it's the dacs din output that's causing it or if it's the cable?
Thanks in advance!
Eric
