Just a quick question, chaps.
I am about to purchase a Hydra for my system, terminated in a standard Euro Schuko plug (I'm in Poland). This will provide power to a CD5, a NAT05 tuner, a hi-cap/NAC72 and a NAP180.
I understand that the earthing for the system is through the CD5 CD player. However, will the tuner affect the earthing, causing a loop ?
Posted on: 17 July 2018 by james n
IIRC from my Naim tuner days (albeit with a NAT 02) this didn't connect mains earth and signal ground so wouldn't cause issues when another Naim source (that doesn't have a ground lift switch) is in the system.
A quick email to Naim would confirm for sure.
James
Posted on: 17 July 2018 by Mike-B
The NAT-05 earth connection is only to the case.
I had a NAT-05 & CDX2 & no problems, now the NAT-05 is partnered with NDX with its ground lift switch on 'chassis', again no problems.
