Help needed, No music store could be located
Posted by: kiba on 17 July 2018
I have a UServe SSD with a NAS 2TB, where 1.1 is used and 800 GB remaining.
Ripped CD with no issues last night. This morning  I it's faulthave this error: "No Music store could be located to hold this ripped cd, more diskspace may become available after encoding of recently ripped cd has completed "
- No changes are made, and to me as 61% diskspace is availabel, I cant's see the Root cause.
- Using Naim Desktop client (NDC), I still have a store for ripped music, and a Scannabel share for my downloaded CD's
I have now asked NDC to make a re-scan, and its done, updating.
Any Ideas??
Posted on: 17 July 2018 by David Hendon
Have you tried restarting the Unitiserve? You need to shut it down properly by holding the front logo for a few seconds and it should start to flash, then when it has gone off, switch the rear panel power switch to off then switch to on again.
best
Posted on: 17 July 2018 by kiba
Yes done that, and the NAS, then started the NAS, and then the US agin
Posted on: 17 July 2018 by Adam Zielinski
I would shut down all network components, including the NAS. Strat them up in the following sequence: ISP modem > router/switch > NAS > UnitiServe.
This way your switch will refresh and may assign new leases to each network component.
Posted on: 18 July 2018 by kiba
Eery thing switched off,  nothing changed.
Using the NDC/tools/systemstatu/music store summary there are 730.000 MB free space
Playback is also ok
But still the same error message trying to RIP, a bit   frustrating :-(
Posted on: 18 July 2018 by David Hendon
Might be worth telling your US where the music store is again.
But if it were me, I would probably ring the factory and ask to speak to Phil Harris....
best
