Ordering internet radio stations on Uniti Atom
Posted by: Richi on 18 July 2018
Hi all, I have searched for this feature extensively, but there seems to be no reference to such a feature. Is this at all possible? I am happy with the list of radio stations on my Atom, but just not with the order of it. Can I change this?
Thanks,
Richard
Posted on: 18 July 2018 by Mercky
Richi posted:
Thanks,
Richard
Unlike the MuSo where you can drag n drop, on the Uniti they will only appear in the order that they are added so you will need to delete and re add. I did send some feedback to Naim on this a while ago as it's a real pain and if it can done on the MuSo why not the Unitis?
Posted on: 18 July 2018 by Klout10
I really hope Naim will solve this in a future update ...
Posted on: 18 July 2018 by GregWPGibbs
Yep, I was surprised when I found I couldn’t reorder the internet radio presets on my Uniti Star. A real pain  if you have a long list in chronological order and you accidentally delete one in the middle ¯\_(ツ)_/¯
I found it most annoying that I was used to a specific order on the mu-so Qb and I’m not able to duplicate that to the Uniti’s ... and no - I don’t want to adjust the order on the mu-so
Posted on: 19 July 2018 by Richi
Thanks for confirming that storting is currently not possible. Let’s hope this will be fixed in the future.
Posted on: 20 July 2018 by Gavin B
Klout10 posted:
Presumably you could delete the favourites from the Unitis, then re-add then in the same order to match the Qb.
Not exactly an elegant solution, but one that should work!
