NDS still faulty!
Posted by: Bruce Woodhouse on 19 July 2018
My NDS dropped a channel last month after a few on off cycles when I was installing new Scap elsewhere in the chain, and also switching off to avoid lightning in the area. Off it went to Naim who apparently fixed some issues and tested it.
Except it is the same. The Left channel is running about 2% volume.
Now I am obviously going to ring service and get some ideas tomorrow but in the meantime all suggestions appreciated.
All other sources are fine. I have swapped the interconnect, no better and used my Qute into the Cd input of the pre-amp which works fine so it must be the NDS.
I have checked the app balance is not off centre. The only thing I cannot switch out is the 555PS as I don't have a spare or an XPS lying around. Note I only returned the NDS and not the PS.
Can anyone suggest something I might try? Can someone explain to me how the power supply delivers to the NDS ie could a fault in the PS explain the issue? I am struggling to work out that it could be anything else, assuming Naim did do the repair correctly.
Bruce
