Spotify to Tidal Playlists
Posted by: Dalamtian on 29 July 2018
Having just moved from Spotify to Tidal can anyone recommend a converter so as I can import all of my playlists, favourites etc? Can this be done to the Naim app version of Tidal?
Thanks,  Nick
Posted on: 29 July 2018 by ChrisSU
I believe there are some third party apps that will help you transfer  playlists, although I’ve never tried them. Nothing to do with the Naim app as such, that just sees your Tidal playlists, regardless of where they were created.
Posted on: 29 July 2018 by Terrysmi
I use Soundiiz - works a treat
Posted on: 29 July 2018 by Dalamtian
Just signed up to Soundizz, as above, worked a treat.
Posted on: 29 July 2018 by Obsydian
I posted a topic in the music room for Soundiiz a few days ago, superb tool gives my Spotify Play Lists in Tidal ad I use both.
