Uniti Star / Nova and XS2 / SN2
Posted by: Emme on 14 August 2018
Sound quality speaking, the amp section of the new Uniti range (Star and Nova) are made starting from the XS2 or the SN2?
Thank you
Posted on: 15 August 2018 by Callas01
Basically yes here a read you can check out. My understanding was both Unitis started with the NAIT as the basis of its design and built up from there.
https://www.naimaudio.com/conn...w-uniti-was-designed
Posted on: 15 August 2018 by Eoink
It doesn't say which model of Nait in that Connections article, and I haven't seen anything written by Naim (there may be something I haven't seen).
Posted on: 15 August 2018 by Obsydian
I only recall it was a ground up new design method of layout, etc ...
