Naim 272 dac quality for roon
Posted by: cuciu76 on 19 August 2018
hello everybody,
id like to buy a nac 272 and the nap 250dr but as you know the 272is not room ready and im a big fun of roon. Maybe a solution could be use it as dac with sonos or allo digi player connected. What do you think about it? Should i prefer the internal streamer to have the best sound quality? (Maybe im thinking that SN2 plus ND5 xs2 is a better solution for my wish to use roon)
tks for your help!
Posted on: 19 August 2018 by ChrisSU
The new streamers are Roon endpoints, i would either buy a separate streamer, or wait for the 272 to be updated to the new platform.
Posted on: 19 August 2018 by Bob the Builder
Using just the 272's dac for roon is a total waste of money. The ND5XS 2/SN2 is a much better solution or get a used pre/power combo 202/200 or 282/200 and add a used Hugo 1 plus a small streamer like a mac mini or even a Raspberry Pi. Another option is to buy a new generation Uniti all in one player.
Posted on: 19 August 2018 by Tallan
My solution to getting Roon (which I also really enjoy) on my 272 is a 2010 Mac Mini I had around.  Like the older MacBook Pros the headphone jack in the older Mini (not sure about current models) supports optical out which is then my input to the 272.  I haven't compared it to other sources critically but it seems very slightly cleaner or crisper somehow.  Anyway Roon is very happy on the Mini - I use it as an endpoint but I'm sure it would perform Core duty equally well.
Posted on: 20 August 2018 by ChrisSU
Bob the Builder posted:
Well it’s not a total waste of money, as it will still work, and as the price of the legacy streamers drops, it might still make an attractive proposition for anyone who doesn’t mind a workaround solution for Roon. A new streamer with native Roon support would of course be neater, and an ND5XS2/Supernait might be better, but until it’s available for demo, that is pure speculation.
Posted on: 20 August 2018 by cuciu76
In term of sound quality, if u have made test, 272 plus 250 sounds better then SN2 plus one of the ”old” naim streimer?
cuciu76 posted:
I thought NDX/Supernait2 sounded better than 272/250DR. This was with speakers that were easy to drive: with more difficult speakers, maybe the benefits of the 250 would outweigh the disadvantages of an inferior source.
Posted on: 20 August 2018 by Claus-Thoegersen
When Naim launced the 272 they said that disabling the streamer made a small difference in sq for the better, but of course most people use the streamer. I suppose that switching it on and off is done in the Naim app, so it should be simple to test.
Claus-Thoegersen posted:
You can disable any unused input on the 272, as you can with any of the streamers.
ChrisSU posted:
cuciu76 posted:
My speakers are ProAc studio 140
Posted on: 20 August 2018 by Huge
One of the things about the 272 is how it improves so dramatically when powered by an external PSU - when powered by a 555DR it's in 300DR class!
Posted on: 20 August 2018 by Ardbeg10y
The Chromecast audio is now a roon endpoint. Not the best streamer ever, but could add functionality.
Posted on: 28 August 2018 by rightcoastants
I also have a 272 and use a Allo DigiOne as a Roon endpoint, connected via coaxial to a digital input of the 272 while running the Roon Core on my MacBook Pro. It is a cost effective way to use Roon and the playback is almost on par with streaming directly from the 272.  Another alternative, is a Bluesound Node 2, which also acts a Roon endpoint and streamer. When connecte via coaxial, the internal DAC of the Node is bypassed. I compared both and preferred the Digione.
I would only choose a 272 if you plan on using the features of a 272 for streaming via UPnP, Tidal, Spotify, etc.
If you only intend on using Roon exclusively for streaming your local music library and online streaming services, there are a few options available for stand alone units that can be connected to a DAC.
