naim supernait and stax srm 1/mk2
Posted by: tony64 on 20 August 2018
ciao a tutti, ho supernait, mi piacerebbe collegare stax srm 1 possibile? I connected amp stax to tape out of supernait but listening level too low
Grazie molto
Posted on: 20 August 2018 by Richard Dane
Yup, no problem, you can use tape out to your STAX SRM1.  Just make sure it's enabled in the socket selection.
Are you using RCA or DIN Tape Out?
Posted on: 21 August 2018 by tony64
many thanks, now it works perfectly, I use pin rca, I selected rec from the remote control and finally I listen properly to the headset from the stax amp.
Tony
