Hiline 4PIN DIN to 2RCA for NAP200
Posted by: stenz18 on 21 August 2018
Can I use the above cable to connect the RCA pre outputs of an Oppo 203 to a NAP200 (for “direct” amplification of the 2 surround back channels)? If not, what cable would I use? Thx
Posted on: 21 August 2018 by Richard Dane
You would need an RCA Phono to DIN4 interconnect.  There's one pictured in the FAQ here;
https://forums.naimaudio.com/t...cs-and-interconnects
A Hiline is probably overkill in this instance but should work fine as well.
