52 Pre Amp Balance Knob crackling
Posted by: Steve2 on 25 August 2018
I am the proud owner of a 52 pre amp which I had serviced about five years ago. If I turn the Balance knob when music is playing from my CDS3 it gives a loudish crackling sound. Yesterday I switched on my system and the right hand speaker was making a crackling sound before I had even started playing any music. I turned the Balance knob and it made the noise louder and the rubber membrane on the bass driver moved quite substantially. It then stopped crackling abruptly. The driver is a Scanspeak 18WU 4741T00. If anyone has any idea what might be causing the problem I would be grateful for your advice or do I just need to bite the bullet and send it back to Salisbury where it was last serviced.
Thanks in anticipation for your time on this.
Steve
