Naim app progress indicator
Posted by: SonicYouth on 25 August 2018
It was always possible to move the playbacked songs (fast) forth and back with your fingertips. Now this feature has been removed. Why?
Posted on: 25 August 2018 by gert
Which hardware are you using and which audio format are you playing? With my superuniti I still can do inline navigation. But it does not work with all formats. flac and mp3 does work, ogg does not e.g.
Posted on: 26 August 2018 by SonicYouth
Android smartphones and tablets. FLAC and MP3. Streaming from NAS via UPnP/DLNA (JRiver).
... and the most important: Mu-So Qb.
Posted on: 26 August 2018 by Simon-in-Suffolk
Also depends on the media server software you are using... not all software supports the fast forward or fast rewind functionality. If the media server doesn’t support the functionality then the ability disappears from the app, albeit the progress indicator with out the circle control remains.
