Unitiqute usb compatibility
Posted by: vtpcnk on 29 August 2018
Hi will a 128 gb usb 3.0 stick work with the unitiqute?
The storage size of the stick and the usb version are my concern.
Appreciate the feedback.
Posted on: 29 August 2018 by Phil Harris
vtpcnk posted:
Neither the size nor the USB 3.0 should be an issue - however it does need to be FAT32 formatted and Windows itself does not allow formatting drives greater than 64GB as FAT32 (although using third party tools you can format devices up to 2TB as FAT32).
Remember than when using a USB device you only have folder and file browsing so your indexing and organising will be very much restricted over what you would expect when using a proper UPnP server so I would strongly recommend using a UPnP server when you have any decent sized collection of music.
Best
Phil
Posted on: 29 August 2018 by vtpcnk
this is for my second room. i had my entire flac collection converted to 320mkps mp3 which came slightly over 100 gb.
