Looking for advice to connect a Phonosofie 3 with a build in PREFIX to a NAIM superuniti
Posted by: rugosoft on 02 September 2018
we "inherited" a LP player Phonosofie 3 with a build in PREFIX and want to use it with a NAIM Superunity integrated device. Recently I have been advised that you need a special power supply for the PREFIX. Apparently the combination of the Phonosfie 3 and PREFIX is a special build solution of NAIM originally designed for a LINN LP player. Does anyone on this forum have an opinion on what would be the best technical solution for this setup? Would there be a power supply available that could be used witout the need to buy a Flatcap or supercap ? And if the only solution would be a NAIM powersupply which one would then be the right choise. I am asking these questions because I get from the NAIM shops so many different stories and I am not a specialist that can interpret the different stories. Would it make sense to invest in a new Flatcap? Or would it be more clever to remove the PREFIX and use a different pre amplifier?
Please help
