Connecting Stageline to Nova, which cable ?
Posted by: joepreppy on 03 September 2018
Hi,
I want to use my TT with the Nova but the NA-52 DIN5 cable supplied with the Stageline doesn't fit in any of the Nova's inputs.
Also, would you have any advise on a power supplier, other than Naim Flatcap?
Thank you
Posted on: 03 September 2018 by Mike Sullivan
I use a Rega phono stage to the Nova RCA inputs (there is no phono connection in the Nova.
Posted on: 03 September 2018 by Emme
Few months ago, I used the Naim i-Supply PSU with the StageLine.
Emme posted:
the interconnect cable was a Naim 4 to 5 pins DIN.
Posted on: 03 September 2018 by joepreppy
Thank you for your replies.
so, from Stageline to Nova is there a DIN cable I could use?
You have to buy the latest version of the Stageline with 2 DIN socket. Connect the iSupply at the 4 pins DIN input and the use a 4 to 5 pins DIN (180 deg) standard interconnect cable from the Stageline to the Nova.
Thank you!
