App Update NDX
Posted by: al9315 on 06 September 2018
I am at a loss to update the app. Got to Google play where I read :-
"PEGI 3" "Installed"
When I open the app it states app version 2.7.0
I thought it was meant to be 2.8 ?
Do I have to uninstall the app and start again?
Posted on: 06 September 2018 by sjbabbey
Are you sure you selected the naim app update from the store? PEGI is a rating system for video games.
Posted on: 06 September 2018 by al9315
Thanks for quick reply will go and investigate - I got an eMail from Naim saying the app was updated, clicked the link provided and ended up where I stated.
Keen - very keen to get it updated - stop re-starting my tablet every time I wish to play another CD rip
Posted on: 06 September 2018 by Mike-B
It looks like the Android app has not been updated on Google Play on my laptop,  it also shows me its "Installed" (on my Android phone).   But touching the Install button on the laptop (& go through the process)  installs version 2.8 on my phone.
I am not very good with tablets, but fine with PCs - The eMail I received had a link, I have now done as SJBABBEY suggested :-
Scrolling down in Google play - it states What's new - v2.7 provides support for the new network players ND555 etc dated 5th September
In the Featured articles from Naim it states v 2.8 ???
Just Install it,  it is v2.8 .....  honest
@MikeB
Thanks - I "think" I have installed it, I am currently updating my NAS firmware, so will try it all later. I really hope it has fixed the loss of connection issue !
al9315 posted:
@MikeB
I can't help you on that one,  I'm a 99.9% iOS app user.   I have the Android installed on my phone but rarely use it
Posted on: 06 September 2018 by Mimi
Android app is being released in stages over a few days I believe, so not everyone will get it at the same time
" Android app is being released in stages over a few days I believe, so not everyone will get it at the same time "
No idea where you found that out, I just wish it was all a little more cut & dried.
I knew we were due updates, but for some the process is not very clear.
I am actually not sure if I have the updated Android app 2.8 or not ??!!
Using the app seems better - does not appear to lose connection with MinimServer, but [click] the About button in the app and it still says v2.7 ?????
To check the revision,  go to the gearwheel tool at top right corner Settings>About & it shows a bunch of info including the app versione number.
I installed it earlier & it is 2.8
Posted on: 06 September 2018 by antony d
I use IPAD to control my NDX download worked first time - V 5.1 like the functionality and new look, will give it a work out this evening
thumbs up from me
Posted on: 07 September 2018 by al9315
@MikeB - I have checked via gearwheel - v2.7
I must be dim - I have done exactly as asked in the eMail I received and see no way to install v2.8
I get to this screen :-
My Android is v5.0 +, my streamer is v4.4
It then states as you can see v2.7 with updated date 5th Sept 2018
WHERE is v2.8 please ?
Posted on: 07 September 2018 by Greg Hepworth
Hi everyone -
Just to clarify the roll out process on the App stores, which covers both Apple and Google Play.  When we release an app it goes into a phased release whereby a certain percentage of users are offered the update at the beginning, and this percentage increases over 7 days until it is offered to everyone.
This is standard practice for many apps and is done to ensure a safe rollout across all our users.
So, I'm pleased that you're eager and I want to get it into your hands as soon as possible, but just hold tight and eventually Apple and Google will ensure everyone gets the update!
Thanks,
Greg
At last I have managed to load v2.8 BUT
I have lost the 'Naim' icon on the tablet desktop - any idea how I get it back (Android) ?
At present I have to go into Google Play and open app
Posted on: 07 September 2018 by Gazza
I have to say the room finding and everything seems faster...crisper. Thanks guys at Naim
Posted on: 07 September 2018 by blag
al9315 posted:
Hi.
The same happened to me, but it was 'hidden' in my installed apps, several 'screens' away. I dragged it back to my Home screen.
As far as I can recall (and at my age, my memory is a thing of the past), other updates to the naim app have not required this intervention.
Hope this helps.
[@mention:53097173002359078] - Thanks, but I think I have tried everything, cannot find a way to get the icon on the desktop ???
Most frustrating !
