Primephonic
Posted by: yeti42 on 07 September 2018
Classical only streaming. Apple have an app but I’ve no idea if/how we can play it through the 555. Wait for Naim to add it or does Airplay have a use here? I’m rather distant from my 555 at the moment.
Posted on: 07 September 2018 by Echolane
Thrilled to hear Primephonic is here.  How do I listen?  I have a Naim Uniti Core.  For that matter I’d like to give Deezer and Tidal a try too.  How do I do that sort of thing?
Posted on: 08 September 2018 by Claus-Thoegersen
They seem to support, airplay, Chromecast (should be the  obvious choice) bluetooth and more ways:https://primephonichelp.zendesk.com/hc/en-us/articles/360006890412-Streaming-with-Bluesound
Posted on: 08 September 2018 by ChrisSU
Echolane posted:
The Core is a server. You need a streamer, or a computer conncted to your DAC, to access these web services.
Posted on: 09 September 2018 by yeti42
Back at home now and started the 14 day trial of Primephonic. Not played any familiar recordings yet but it plays on the 555 through Airplay via the music bit of the control pannel. I’ll let the system warm up a bit before a serious appraisal, it’s been unplugged for a week.
Posted on: 10 September 2018 by Alley Cat
yeti42 posted:
The disadvantage of Airplay is that it will send CD quality only, but has the advantage normally of playing gapless which can be important for many albums, classical or otherwise.
Chromecast can support hi-res audio, but if the 555 is like the Uniti devices it may not play gapless - at least Qobuz will not for me.  (Have you trialled Qobuz if available where you are?)
Primephonic say they're 're-platforming' and Chromecast support is on hold:
Ensuring the functionality of our service with Chromecast is one of our highest priorities, however, due to the upcoming re-platforming of Primephonic which should take place in August, all integration projects, such as Chromecast have been temporarily placed on hold in order to avoid technical issues that could be caused as a result of the re-platforming.
Please rest assured that this integration is still one of our projects, but will take place later on this year. For more information on this release, please make sure that you are signed up for our newsletter by going to the notifications section of your account.
