Naim speakers can't connect to my Smart TV
Posted by: Michael Giggs on 10 September 2018
Anyone who have tried connecting their Naim audio system to their smart tellys?
I can't seem to do it with my Decovue (has an android box in it).
Please help!
Posted on: 10 September 2018 by hungryhalibut
I connect my Panasonic to the 272 with a toslink cable and it’s fine. What connections do your TV and stereo have?
Posted on: 11 September 2018 by Mike Sullivan
I use optical out of the tv to an optical in on my Nova and UC2. If you RCA out of the TV, that’s another option.
Posted on: 11 September 2018 by David Hendon
I also use an optical cable from my Sony  TV to my 272 and it works fine.
best
Posted on: 11 September 2018 by Richard Dane
I use TOSLINK optical cables from my Sony TVs into a Unitiqute 2 and an AV2.
Posted on: 11 September 2018 by Karl
I use the headphone out on my Sony to my 282 pre amp.
Karl
Posted on: 11 September 2018 by james n
Michael Giggs posted:
Please help!
Hi Michael - It would help if you mentioned what Naim kit you had. The best way (as mentioned above) is optical via toslink but to do this you will need a Naim box that has digital inputs. It's difficult to find info on the audio output from your TV but i would assume it would have a standard toslink connector there somewhere to take the signal out. It will need to be set to stereo PCM (you should find that setting in the TV setup menu)
