Naim nap 300
Posted by: Naimark on 13 September 2018
hello everyone,
could you please confirm that both nap 300 and 300ps cabinet finishing/material/treatment is the same?
Would it be possible that ps300 seems to be rough rather than smooth?
thanks in advance for your support
best,
mark
Posted on: 13 September 2018 by hungryhalibut
They are both the same.
Posted on: 13 September 2018 by David Hendon
They should be the same finish and I would expect the two serial numbers to be quite close.
best
Posted on: 13 September 2018 by Richard Dane
IIRC because of the nature of the process and finish there's a tolerance on the powder coated finish of the regular sleeves.  As such, while both sleeves should be very similar in finish, there's always the possibility of getting a pair of sleeves at the opposite end of the tolerance.
If it's an issue then you should consult with your supplying dealer who can then take a view as to whether it's within acceptable limits or not.  If it's an extreme difference then they can take it up with the factory to try to get a closer match for you.
