iOS12?
Posted by: gert on 17 September 2018
Does anybody already have tried if the naim app does work with iOS12?
Posted on: 17 September 2018 by Mike-B
Yes it works just fine,  TBH I can't detect any difference
Posted on: 17 September 2018 by hungryhalibut
Yes, it’s fine on both iPad mini 4 and iPhone 8.
Posted on: 17 September 2018 by gert
Ok, thank you both for the response. Then I will update my ipad mini 2, too.
Mike-B posted:
I should add that I've not experienced any of the discovery or crash issues reported on the forum, & that includes a long string of beta series 5 apps.
My main devise is iPad 9.7" 2017    Also have the iOS app installed on wife's iPhone 6 & that working fine as well,  my own phone is Android.  The other relevant parts of the system are:    Synology DS214 + Asset UPnP (beta)     NDX f/w 4.6     BT HH6 'router' & all wired network via Cisco SG110D switch.
Posted on: 18 September 2018 by gert
gert posted:
FYI: The ipad and the naim app still work with iOS 12. And I think it really does respond a little bit quicker now (the iOS GUI, not the naim app). The last major updates always made it a little bit slower than before. So far I can recommend to do the update.
Posted on: 20 September 2018 by sktn77a
Anybody tried n-Serve with IOS12?
