Headphones questions
Posted by: al9315 on 20 September 2018
Thinking about perhaps getting a pair of headphones to extend listening times !
1) Are closed back headphones silent to other people in the same room?
2) I would wish the cable(s) to extend to up to 3 m from back of pre-amp to chair, is this possible, or are short cable runs desirable - I imagine headphones come     with a fixed length cable say 1.5m - so I would have to have a cable from - pre-amp to headphone amp 1.5m ?
Reading a few threads a little hwile ago on here, it appears the Rega rHead is good value, and someone I think bought a pair of Quad ERA headphones recently.
I do not have a fixed budget in mind, but perhaps £500 - £700 is feasible.
Was thinking of waiting until Hi-Fi show next Feb and trying some there, but always a lot of distractions.
I do not currently have a dealer, but would consider one, if I knew they had a selection to try from, would be nice to have a shortlist.
Any ideas most welcome - thanks
Posted on: 20 September 2018 by Richard Dane
It looks like you're just in time for the Festival of Sound in London at the end of this month.  I think there's an attached "Headroom" section too where you can see and audition lots of headphones, headphone amps etc..
Posted on: 20 September 2018 by ChrisSU
Maybe worth getting in touch with HiFi Lounge, who have a dedicated headphone shop with a wide selection. I’ve found them to be helpful in the past.
Posted on: 20 September 2018 by intothevoid
re. Q2 - there are lots of cans with detachable cables (therefore upgradeable to longer lengths).
Posted on: 20 September 2018 by fathings cat
Before jumping in with an expensive option first job is to ask your self will really use them. I have a Sennheiser hd700 and mojo but I think I use them once in a blue moon.
Maybe consider a used option at a cheaper price and assess from there.
Gary
Posted on: 20 September 2018 by Peter1480
At that price range there is a lot on offer but you really need to do some listening head phones sound is a very personal thing for sound and fit! Re 1, almost depending on the volume. re 2, Rega ear, Arcam rHead or the Pro-ject head box S2 are woth a listen, with a QED cable to get it close to you listening place. Try to listen to Fostex, Bowers & Wilkins, Sennheiser and Beyerdynamic in the £400-500 range. Also worth considering if you need noise cancelling if there is background noise is Sony.
Posted on: 21 September 2018 by JedT
I just spent £700 on some beyer amiron homes and a (second hand) chord mojo. I'm very happy and I think they'll get a lot of use as a lot of my listening time is late at night when enjoyable volumes through my speakers make the family grumpy!
Posted on: 21 September 2018 by PaulM160
+1 to both Richard & Chrissu's suggestions - HiFilounge have a great selection across price ranges. You will need to give yourself some time to listen though... Paul & Wendy are great; they will most definitely listen to your requirements, suggest options and then leave you to assess in your own time.
Posted on: 21 September 2018 by al9315
Thanks for all the replies - very helpful. I like the HiFi Lounge suggestion but they are a bit of distance from me
I am going to try to go to the show in Hammersmith next week, and see how I get on there first.
Can wireless headphones be a successful option, or are wired still best ?
Posted on: 21 September 2018 by Peder
???? AL9315,...Wired.
/Peder????
Posted on: 21 September 2018 by Perol
al9315 posted:
Lots of choices within your budget
Get a good dedicated amp, something like Violectric or Lake People (related) and try some AKG, Sennheiser or Beyerdynamic cans
So many to choose, my experience with K701 or K550/III, DT 250 or 880, HD600 etc..they all are great below the €300 point
Trying yourself is essential, both for comfort and if you want closed or open, above is just an appetizer - much more out there
Posted on: 21 September 2018 by james n
PaulM160 posted:
Wow - that's quite a place. Could be dangerous for the wallet
Posted on: 22 September 2018 by PaulM160
yes indeed.....there is no such thing as just a casual visit I have found.....easier to hide the car keys
Posted on: 22 September 2018 by Adam Zielinski
To answer your first question:
No - closed back headphones will not be silent to the other people in the room. Generally there tends to be quite a lot of of sound ‘bleed’ into the room.
