Think I am being dumb and blind!
Posted by: Popeye on 20 September 2018
hi Guys
If using a Hicap on a Supernait2, I am right in thinking the hicap then powers the preamp and the existing power supply powers the internal amp only, is this correct?
thanks
Posted on: 20 September 2018 by james n
Yep.
Posted on: 20 September 2018 by snowfoxx
Yes, u r right.
And your current setup sounded better than stand alone Nova ?
Posted on: 20 September 2018 by Richard Dane
Correct.  However, remember that when you add the Hicap the pre-amp signal goes through it (thus keeping system and signal earths close together for best performance), so you need to connect a SNAIC4 from the Hicap signal out to the Supernait2 Power Amp IN in order to get the pre-amp signal to the power amp in the Supernait.  Thus, to connect a Hicap to a Supernait 2 you need both a SNAIC 5 and a SNAIC 4.
