552 leds will not turn off
Posted by: Richieroo on 22 September 2018
Hi I have returned from holiday and powered up my system .... everything is great apart from. The 552 leds are not switching off ... using remote.....the nds remote used to work it.... can anybody help....
Posted on: 22 September 2018 by sjbabbey
I’m not familiar with the 552 remote but does it have separate device buttons in which case try pressing the “pre” button and then the display button.
Posted on: 22 September 2018 by Richard Dane
Try power cycling.  Then allow time for the pre to come out of mute.  then toggle DISP in Pre mode on the Narcom remote.
Posted on: 22 September 2018 by Richieroo
Hi pre and disp worked a treat thank you
