Supernait 2 update usb?
Posted by: Popeye on 25 September 2018
hi guys
what can be updated on the Supernait2, as it has a mini usb on the back for updating purposes.
have there ever been any available updates for this?
thanks
Posted on: 25 September 2018 by Richard Dane
It's most likely for updating the control/logic firmware.  I'm unaware of any updates for this, so far...
From the user manual:
4.10 External Control and Interface
The Supernait 2 is fitted on its rear panel with a 3.5mm jackRemote In socket and a mini-USB interface socket.
The Remote In socket can be used for RC5 remote control of the Supernait 2 via a wired connection or a remote IR repeater.
The mini-USB socket enables firmware upgrades and diagnostic tests to be carried out. Contact your Naim retailer for more information if required.
Note: The mini-USB interface is not intended for the connection of USB memory devices.
