streaming stops at end of songs
Posted by: Renato.Stein on 25 September 2018
Either an album will start playing not in order and it will always stop the song a few seconds before it is supposed to end when I play Tidal through the Naim App. I have the Uniti Atom for months now and this problem started only a few weeks ago. And it does not go away. I have reinstalled all software and the problem remains.
What should I do?
Posted on: 26 September 2018 by SimonPeterArnold
Tidal have been having some network issues recently. I would though restart all you network gear as a first step to see if it helps.
Posted on: 26 September 2018 by Clive B
Power off, wait five minutes, power back on. Try that - it's what unlocks a similar issue I experience occasionally on my NDS (although I usually only wait 30 seconds or so).
