Core Ripping Issue
Posted by: DM on 28 September 2018
My Uniti Core has issues ripping discs from multi-disc box sets. The first disc in the set rips and then the second rip erases the first. To be clear, this doesn't occur will, but many multi-disc releases. Creating a playlist, editing meta deta, nothing has worked.
Any suggestions welcome?
Posted on: 28 September 2018 by David Hendon
This is a known bug and Naim have a fix in the works so just wait for the next Core firmware update.
best
Posted on: 28 September 2018 by Bart
Assuming you don't want to wait, the better solution is to rip it yourself on a computer, edit the metadata, and then copy the files over to the Downloads folder on your Core.   Just as if it were a $400 nas . . .
Posted on: 29 September 2018 by Rich 1
I've had this problem as well and like Bart I use a computer. The excellent free Exact Audio Copy suits me. To be fair it's possibly an error in the Redbook interpretation on the CD that makes the Naim app think it's the same cd even though the song titles are different. Don't chuck the Core out and assume that a NAS will sound the same though. It'll sound different but only your ears will confirm which plays music better. Off topic, I'd advocate comparing a Core and your Nas at home before choosing. Rich
