Can the XS 2 drive Focal Aria 948 ?
Posted by: Frenchymanholow on 28 September 2018
Hello everybody!
I couldn't find the forum section dedicated to presentations of new members, so here I am: Paul, 27, french and new to the Naim world.
I listened to the speakers Focal Aria 948 on a Naim Nait XS2 (70w) and I fell in love with the couple!
However, some professionals tell me that this amplifier is too "weak" to drive these speakers.
What do you think of it? Have you ever listened to that association aswell ?
Details about the Focal Aria 948:
Type Three-way bass-reflex floorstanding loudspeaker
Speaker drivers Two 81/4" (21cm) Flax bass
61/2" (16.5cm) Flax midrange
1" (25mm) Al/Mg TNF inverted dome tweeter
Frequency response (+/- 3dB) 37Hz - 28kHz
Low frequency point - 6dB 31Hz
Sensitivity (2.83V / 1m) 92.5dB
Nominal impedance 8 Ohms
Minimum impedance 2.5 Ohms
Recommended amplifier power 50 - 350W
Crossover frequency 280Hz / 2600Hz
Thank you for your help!
Paul
Posted on: 28 September 2018 by pamzz
Sure it can , i already listened to them ,focal also have high sensitivity ,
Posted on: 28 September 2018 by Frenchymanholow
pamzz posted:
Hello pamzz,
That is exactly what I calculated too!
However this technician told me that it would be hard for the XS 2 because of the two 21 flax bass drivers...
Posted on: 28 September 2018 by MDS
Focal speakers are usually easy to drive. And the output specifications of naim amps understate just how powerful they are when you hear them. The XS2 should be able to drive those Aria's easily. The stuff about the flax bass drivers is nonsense.
Posted on: 28 September 2018 by Christopher_M
MDS posted:
What do you make of the speakers' low impedance though, Mike?
(My Q slightly hedged with the fact that Paul has heard the combo and likes it).
Posted on: 28 September 2018 by Simon-in-Suffolk
Indeed a 2.5 ohm impedance dip is going to cause some issues with many amps.. even if a bit of glare or unwanted prominence. I would ensure you have a meaty amp to drive...
Christopher_M posted:
MDS posted:
I don't how relevant that is in real world terms, Chris. I've yet to hear a pair of Focal speakers that can't be driven by naim amps.  For example, I was really quite surprised at the power and sense of fun I heard when my dealer paired an Atom (I think) with Kanta 2s.  I believe the Atom is rated at only 40 wpc.  The Kantas have flax drivers, like the Arias.
Posted on: 28 September 2018 by RaceTripper
I still recall in the 80s when I worked for a Naim dealer as a classical/jazz record buyer. I was not involved at all with Hifi sales, etc. I had a 150 WPC McIntosh system of separates I was very proud of. The owner sent me home with a Chome Bumper Nait (what, like 20 WPC or something?) and asked me to try it.
It was no contest, the Nait put that McIntosh system to shame. It was punchier, louder and more detailed. It sounded better in every way. My wife noticed the same instantly. I listed my McIntosh system for sale the next day, and bought a 42.5/HiCap/140. That was my introduction to Naim.
Naim amps can boogie like crazy and drive difficult speaker loads very well. I'm currently running a 250DR into a pair of Dynaudio S3.4s (which have 4Ω nominal impedance). It's delicious.
Posted on: 28 September 2018 by Daniel H.
Alan Sircom on Hifi+ recently reviewed the Uniti Nova with the Focal Kanta 2. The Kanta also has flax drivers, and the Nova had no problem driving them.
Posted on: 28 September 2018 by wenger2015
Hi FRENCHYMANHOLOW,
Welcome to the forum.
Not so long ago I was pairing a Supernait 1 with a set of Focal Aria 926’s...... it was a very good combination that worked well.
As MDS has already mentioned focal speakers are reasonably easy to drive....
Posted on: 28 September 2018 by mpw
The spec sheet mentions 2.5ohm as the lower point.  I would prefer at least a SN2 if not more.. Depending on the room and the volume levels you listen to.
I am not convinced the XS2 will be able to provide the headroom needed.
Posted on: 29 September 2018 by Frenchymanholow
So what would be the risk ?
Not enough/clumsy low frequencies ? Damaging the amplifier ?
Also I thought that the lower the impedance of the speaker, the more power an amplifier can deliver... that makes me lost.
Thanks, Paul.
Posted on: 29 September 2018 by mpw
View it like this. .
The speakers pull current from the amplifier
Not that the amplifier pushes current to the speaker
More transformer power now leads to more headroom which means that the amplifier able to meet what the speaker asks for  ( what the music requires  )
Zero impedance is a short circuit
2.5 ohms demand means the speaker will pull more current at lower frequency
Since the SN2 has a more powerful transformer. .it will be able to send more current.
All this excludes the possibility that your room is small enough for the XS2
But a smaller room and a floorstander means that you might have to give adequate breathing room to the speakers
PS. : my speakers demand 6 ohm at lowest frequency 50 hz so my Amplifier haS to work less as compared to a speaker demand of 2.5 ohm
Hope I am making sense and able to explain
 PS2 ... Nothing like a home audition
Thank you MPW, my room is 35 sqm.
I = U / R so I get the point yes; indeed.
Thought lots of people argue that the announced watts on Naim products are very conservatives, and that it can deliver much much more. What do you think of that ?
In the case that it wouldnt be enough; how would the addition of a NAP help?
A SN2 will be a good start point ..from the Naim range
Above this. .the better power. The better for the music assuming the source is up to scratch
That will also depend on your budget..
These focals  can handle up-to 350 watts. .
The SN2 can do 135w at 4 ohm which is quite good... For many speakers
My friend. ..YMMV applies
If you look at Naim separates I would look at the 250 DR with pre.. At least
But that leads to more outlay. ..
As a SN2 owner and a previous Naim Nair 5i2 owner. .I Am quite happy with my amplifier
