NDX display brightness setting
Posted by: PTCM on 28 September 2018
Can someone please tell me where the NDX display brightness setting is ?
didn't turn on the machine for a few weeks.  I can barely read the display.  Please help.
Thanks a lot.
Posted on: 28 September 2018 by NickSeattle
My NDX-FM went dim last year.  Had to have it repaired through my dealer.  Only had to pay shipping one way.
Nick
Posted on: 28 September 2018 by ChrisSU
Yes, it’s possible that the display is faulty snd may need replacement, especially if it’s a few years old and you have kept it switched on.
Posted on: 28 September 2018 by Richard Dane
While OLEDs are likely a good choice for keeping display noise down (so good for high performance audio products), it would appear judging by reading reports across the 'net of different makes and models that longevity can sometimes be an issue, and was certainly a big problem in the early production of things like OLED TVs.  FWIW, I'm told Naim have moved on to using improved screens (or no screen in the ND5xs2) in the new range. For all that, I have yet to have a failure or dimming of the OLEDs on my devices even after a number of years constant use, but then I'm usually quite careful to ensure that they are set (where such settings exist) to turn off after a few moments, or perhaps I've just been relatively lucky.  Either way, it's a good practice to ensure you have the display settings set to dim the display after a button press or function change.
The good news is that AFAIK Naim should still be able to supply a replacement OLED screen for anyone who has been unlucky and had one fail.
