Nac 72 revisited
Posted by: MangoMonkey on 28 September 2018
I got a reserviced and rebuilt Nac72 delivered to me a couple of months ago. I just got around to installing it. It just sounds beautiful!!!
System is: Naim Dac (fed via optical in from my PC - no audiophoolery) into Nac 72/HiCapDR/Nap250DR into Harbeth SHL5+s.
Olive's still where it's at. ;-)
Kudos to Chris West for an excellent restore job on the Nac72. This beats any of the current naim preamps for value.
The edginess of the olive goes well with the laid back Harbeth. Perfect balance.
On a different note - the ND555 design was a let down. Not sure why they put a screen on it. Just costs $$$ - and doesnt add any value since most operations are via the phone only.
Naim should've saved the trouble of engineering the screen and included an ipad instead.
Posted on: 28 September 2018 by Bob the Builder
It certainly is a great little pre and the interchangeable boards are a beautiful piece of engineering and a great user friendly idea. Hope you continue to enjoy MM.
Posted on: 29 September 2018 by Ardbeg10y
MM, what's your opinion on pairing the Nac 72 with DR-ed equipment?
Posted on: 29 September 2018 by feeling_zen
The 72 had some of the best (maybe the best) cost performance of all the preamps.
72/HC/140 was just such a dinky little high end system that hardly took up any room. May shoebox seperates live forever!
Posted on: 29 September 2018 by HiFiman
I love the 72, owned three over the years and I think it's one of the best analogue pre amps Naim have built.
Adding the Hicap DR would be very interesting wonder what this brings in performance.
Posted on: 29 September 2018 by ngarritson
Mango Monkey,  great to hear you are enjoying your rebuilt 72 so much.  I too have a 72 that Chris West performed the same magic on and my experience with it is very similar to yours.
Coincidentally, I took delivery yesterday of a 140 from Chris yesterday after undergoing a full rebuild.  Now I have a 72/hicap/140 that he has fully rebuilt.  The rest of the system is CDX/XPS, Rega P6, and Allaes.  There aren't enough superlatives.  It's simply exceptional.
Can the 72/hicap/140 combo be beaten when it's operating at this level?  Perhaps in some areas, but in terms of synergy and musicality I doubt it.  To top it off, the value for money is off the charts.
Posted on: 29 September 2018 by fatcat
Interesting that Chris (probably the No.1 naim service technician this side of the Mason Dixon) swaps the BNC sockets out, for RCA, and regards it as an upgrade.
Perhaps the theory that BNC is superior is wrong.
Posted on: 29 September 2018 by MangoMonkey
fatcat posted:
I asked him to do it. My Rega RP6 has rcas.  I don’t have the time to get bncs on it.
The RP6 into the Nac72 does sound better/smoother than the AlloDigiOne/NaimDac into the Nac72. The Nac72 was built in the era when Vinyl reigned supreme. ;-)
I suspect its the AlloDigiOne that causing the Naim Dac to sound a little 'hot'.
fatcat posted:
I wouldn't necessarily draw that conclusion.  In my case he took out the BNC sockets and replaced them with WBT RCA jacks because I use a Rega turntable which of course has RCA terminations.  I am unlikely to ever get an LP12 so there was no point leaving the BNC sockets in place.
I would also suggest that geographical boundaries are of little use in trying to understand the level of Chris's skills!
Maybe the 72 / HiCap DR is the hidden gem, so let's say £400 for a great used example of the 72 and £800 for a used HiCap DR so around £1200 for an exceptional Naim Pre amp, enough said.
Sounds like a great setup Mango
Posted on: 29 September 2018 by leni v
Olive 250-72 here.CHANGED MY CB HC 3 YEARS AGO TO AN HC DR.GREAT UPGRADE.
How does the Olive 250 compare to the Nap250.DR ...?
Oh - and I forgot - I also happen to have the newer naim speaker cables.. superlumina..
MangoMonkey posted:
Thanks. I have an Allo Digione into a Chord Mojo, this does not sound hot, but smooth. I must say that I still want to get a Naim Dac when funds allow.
I now and then miss the guts which my Supernait 1 has.
MangoMonkey posted:
Before my 250dr I had a CB250 with olive fascia and Naim service completed in 2017.
The 250 DR pips it but only just, once listened to a 250.2 and this was not for me.
In my opinion the olive or CB250 (serviced) is closer to the 250dr then a 250.2.
ngarritson posted:
fatcat posted:
Well, if you take a look at his website, you will see a photo of the back panel of 62 with the title.
NAC 62 preamp, Olive era, upgraded with WBT Nextgen RCA jacks.
OK, he's probably naims best service technician both this and the other side of the Mason Dixon.
fatcat posted:
ngarritson posted:
fatcat posted:
Oh I see.  I couldn’t tell you if they are suggesting WBT RCAs are an upgrade over BNCs.  I know they certainly regard them as an upgrade over standard RCAs.
Posted on: 29 September 2018 by Adam Zielinski
A classic (and a classy) combo - I also drive mine with an nDAC, but use Quad ESL-63s
Posted on: 04 October 2018 by MangoMonkey
I just sold off my Nac272.
AlloDigiOne -> Naim Dac -> Nac 72/HiCapDR replaced the Nac272.
Posted on: 05 October 2018 by ROOG
MangoMonkey posted:
This is interesting, I have been 'scared off' from buying a nac 72 to front up my nap 300 power amp.
I would be interested to know if a freshly serviced nac 72 be a reasonable 'good value' pre for the 300?
Posted on: 05 October 2018 by Ardbeg10y
A 300 is not the max for the 72. See this bloke on youtube:
Posted on: 05 October 2018 by tonybabawalla
'I just sold off my Nac272.
AlloDigiOne -> Naim Dac -> Nac 72/HiCapDR replaced the Nac272'
Mango Monkey, is the DigiOne also a streamer then? Or what app do you use to render from your PC to it? Thanks
Posted on: 05 October 2018 by MangoMonkey
The DigiOne is ONLY a streamer. It takes in an ethernet connection and outputs an extremely low jitter digital out. They don't do optical out since they can't get the jitter down on it.
This supports both roon and upnp. I wanted Roon on this system - and it was cheaper to go down this route rather than a naim based solution.
(I had to budget for a ND555 in my main system).
Posted on: 05 October 2018 by ricsimas
I went from a 282 to a 72 in my system (which has eventually migrated from black to olive). It's a great preamp, and I thought there was very little between those two.
I'm now running it as 72/SC/135s (all serviced in the last 3 years at most) and I don't think I'd have any qualms fronting a 300 with it other than the somewhat silly look of the combo. :-P
Posted on: 05 October 2018 by Bananahead
I went from a 72 to a 282 and, to this day, it is the single greatest upgrade that I have ever made.
When I upgraded from a 282 to a 552, I sold off the 282, and used a Nac72 for a few months while the 552 was getting built for me. Funnily enough, I didn't miss the 282 much...
